I searched CFM 383 on mud with no luck. Please hook me up with a thread you know of that might help me. I have a 383 stroker with a RPM air gap manifold. The motor is claimed to be 410 hp and 420 lb torque which ?? it only has 9 to 1 comp with 76 CC Heads that have 1.6/2.02 SS Valves and Flat top pistons
The cam is a .480/.480 -230/230/110. the motor does have the capabilities of RPM's with good vavle springs, screw in studs, guide plates, good bolt kits, balanced, etc. but I dont plan on winding it that hard. Infact I threw 2" ramhorns and a walkers crossover pipe on it since I only plan on usnig about 4500 rpm's of it for the most part and thought I would sacrifice HP for a bit of torque. My problem is when I use all the CFM calculators they tell me at 6500 (which is what the intake is rated at on the high end) the motor will need around 650-680 cfm pending the efficiency. Everything I read and am told so far says no way it will be flat on the top and to go with a 750 and 700 minimum . I am currently looking at a Truck avenger holley which leaves me with either a 670 or a 770.
Any help would be appreciated.
