What are you working on? (15 Viewers)
I previously replaced the left rear bumper end cap on my 62 because it was pretty dinged up. Finally decided I should replace the other three.
These bad boys arrived today and I’ll likely install them either tomorrow or Monday.
Made up another Slee adjustable panhard bar and installed a rear DeltaV panhard bracket on the 93 80 I am putting together.
How does she handle on the road (and off)? Looks pretty damn badass.
It should handle as well as my burgandy one, and it handles great, basically the same lift minus J springs in the front of this one I the other has heavy's. same spring rate but 1" height difference. This one is on 35's, while the other is on 33's. Off-road, should be good. I need to get the brakes bleed better before I drive it more than just the driveway. I still have a few more items to install but want to drive is some first.
Drove the 93 around the neighborhood. Low fuel light came in so headed home.
This one had not been out in over two years. Needs to stretch its legs!
It was a great time as usual. CLCC has taken this event over from us for the past 3 years and really done a good job. I think almost 100 rigs showed up. I do not think I took a single pic but will had some sent to me. Let me see if I can post some later. There are some posted over in the CLCC clubhouse.
ARB/IPF harness upgrade for my 62 is mostly complete. Waiting on H1 bulbs for my high-beam housings.
Last night I tested out the new headlights on some rural roads outside Richmond. Amazing upgrade. And my yet-to-be upgraded stock high-beams were brighter too just from the new harness.
Today I adjusted the aim of the lights downward. Last night I was likely blinding oncoming drivers because the beams were pointed too high.
I will post night pics when the highs are installed.
I got the 93 traded and now sporting a 2017 4Runner Limited. I swapped the wheels with some take off SR5's and added some 265 BFG's and a 1" spacer kit in the front
