I've got a wet floor on the driver's side. Can't figure out the origin for the life of me.
Sunroof drains clear and clean, drain quickly to the base and I recently chased them
Cowl drains drain fine
Suspects:
when the AC is on plus cool box, a little water comes over the transmission from the evap coils but it's not as much as I think it should be.
Q: are there more drains other than over the transmission for the AC/cool box? Is there any way to clean those drains from under the car? Water is definitely only coming down from over the trans for the AC.
Suspect 2:
The sunroof seal is sun damaged, it looks like it's shrunken. Is it possible the bad seal overwhelmed the drains?
Before I found the water I did get a car wash, but I found the water halfway through a 15hr road trip through the south. I can't figure out which it is, evap or sunroof...
Things ive done:
Chased drains
Dumped a bucket of water on the sunroof and the windshield with the carpet pulled up (no sign of the source, it's just...wet. )
Any ideas would be appreciated, I'm a bit stumped.
Suspects:
Suspect 2:
Things ive done:
Chased drains
