Press all da buttons at da same time It'll do summtinI literally just bought my first Chinese welder and I’m still watching YouTube videos trying to figure out what the buttons do, I would be proud to call that one of my welds!!
I doubt any practicing PE would answer the questions over liability concerns.Does anyone make the information available to the public, I looked at:
The National Institute for Automotive Service Excellence (ASE)
The Society of Collision Repair Specialists (SCRS)
The Inter-Industry Conference on Auto Collision Repair (I‑CAR)
And nothing easy jumped out at me. It would be cool to find a trusted source of information for us home built guys to reference. Hoping someone with better Goggle can jump in and find something.
Some random thoughts that would be nice to get the experts opinion on…
If it’s unknown mild steels, high-strength steels, ultra-high-strength steels do we assume at least (HSS) and proceed with best practices for that?
Holes are typically points of increased stress. Round holes are typically worse than ovals. None of us have the engineering data on a fj55 frame to run the FEA.Pre heat and post heat always or not needed. If no pre heat should the moisture be chased out of the parent material before welding, if yes only acetylene or is propane okay?
Fish plates, needed or not needed. If needed when are they needed?
Supporting the area to be welded, needed or not needed. If needed what’s the best practice for a guy at home?
Welding start and stop locations, matter our not. If it matters what do we need to consider when planning out our weld strategy?
Drilling holes and random spots on a crack repair, needed or not. If needed where do we put them?
Vertical welding yes or no. If yes up or down, any special precautions?
I’m sure we will have more questions but this kind of covers what I see most repeated with guys trying to help each other on their projects.
I say in general if I don’t know its mild steel less than 0.3% carbon then I assume it’s not and assume that it’s at least 0.3% to 0.6% carbon and would use pre-heating and post-heating to avoid cracking during the welding process.Why would you assume this given they weren’t used on 1970s era Toyota trucks and the welding properties are so very different?
Read the book, Jim. Or don’t. ¯\_(ツ)_/¯
Does your book suggest this is not a good practice? Yes I will read it when I get a chance but you seem to already know the answer so just tell me I’m wrong if I am and I’ll learn something new today!
Do you know the carbon content on 70’s era frames? What would you personally do before you welded on one?
So what do you believe the carbon content is in a 70' Toyota frame and would you pre-heat before you welded it?It’s not my book.
JIS has standards (or did in the 70s) for the steels used in automotive frames.
I am reading along here with interest. I don't have the background to dig in deep, but can we ping any of our Australian friends who have gone through modification as their gov has strict rules on modificaitons? I did a surficial search and found this: National Code of Practice for Light Vehicle Construction and Modification (NCOP) and VSB6 – National Code of Practice for Heavy Vehicle Modifications; but I didn't see any specific regs under it that outline requirements. Likely the government defers to stamped drawings to put the liability on the engineer, but maybe there is something there
Do you believe pre-heat or chasing the moisture out of the base metal is a bad idea before welding on a frame if you don't know the carbon content or you even if do know it is less than 0.3%!I don’t believe any pre-heat is necessary at the thickness found in a light truck frame of that era.
I don't believe it's a bad idea. I used this method on winch mounts made of C channel and hot rolled steel plate. The channel was 3' tall and welded upright on a 2' square hot rolled plate that was 3/8" or 1/2" thick and welded entirely around. I will try to answer the reast of your questions above.Do you believe pre-heat or chasing the moisture out of the base metal is a bad idea before welding on a frame if you don't know the carbon content or you even if know it is less than 0.3%!
I would'nt be so sure about that! HSLA ( high strength low alloy steel.) Has been around since the 50s and 60s and AHSS (advanced high strenghth steel.) Came shortly after. So the HSLA could have been used as early as the late 50s or early 60s in automotive framesI believe they are low carbon steel. I don’t believe any pre-heat is necessary at the thickness found in a light truck frame of that era.
I read the JIS standard he posted and only found references to thicknesses nothing about carbon content on automotive frames specifically but I didn't want to argue so I just agreed that he was right.I would'nt be so sure about that!
1st let's get back in focus on the purpose of this discussion and not make it a Pissing contest. The focus in on the regular Joe Smoe working on his pride and joy in his garage or ( on da ****ing ground in da dirtI doubt any practicing PE would answer the questions over liability concerns.
I would'nt assume mild steel on any automotive frame, it would flex too much. So I believe all frames have a certain carbon content and it allows flex and still maintains structural integrityI read the JIS standard he posted and only found references to thicknesses nothing about carbon content on automotive frames specifically but I didn't want to argue so I just agreed that he was right.
But I also agree with you that I wouldn't be sure it is mild steel and most likely has a carbon content as high or higher than what would traditionally be considered mild steel here in the US..
