May be. With the weld splatter still on the spacer, it looks obvious it was welded in place. Weld splatter may have also made it out to the wheel bearings and if the axles are the style without inner races, the axles may be damages on the outer ends as well.I wonder if the axles are already damaged though.
I snapped a pin in half and had a very wallowed hole. A carrier is cheap. And you could learn how to setup a diff if you rebuild it yourself.I will def check the pin and the holes for any abnormalities.......I knew there would be a catch somewhere![]()
I know why. As with my P.O. whom I know well. He had no skill to install a lunchbox locker or knew anyone to do it for free. He did however get a welder to weld them up for free. Did it in place and they broke loose the first time and required re-welding. When I got it, it held for about 18 years then busted loose again. That's when the lunchbox went in. But the debris had wiped out the axles & bearings. "Spider Gear Weld Fail"Why would someone weld the diff when lunchbox lockers are reasonably priced?
I noticed that too.Did the bearing surfaces survive the weld splatter? Those later axles don’t have an inner bearing race and the balls of the axle bearing ride on the axle.
