That's coming together nicely! Are you painting the roof white on top of the red, or doing the whole thing red?
Love it! Looks great.
Dan
Dan
Ian,
Looking good !
After viewing your photo, I must ask: how often, if ever, do you guys need to use windshield wipers in your environment? Similarly how often a heater; and how does one avoid using an airconditioner, or does the desert heat simply become an accepted way-of-life?
Ian,
The 1979 and up 40s had optional factory airconditioning.
As well as optional power steering and front disc brakes.
World market trucks from October 1982 up had optional H55F five-speeds available: for diesels or gassers.
The parts should be available on used Middle Eastern vehicles, to look at the layout, and to pull.
I thought I saw a factory airconditioning evaporator unit slung under your dash in one of your prior photos.
While standard airconditioning can be fitted to a Troopy, the huge expansiveness of the vehicle makes cooling only the front seating area viable. Here in the US, the biggest vehicle manufacturers install a second evaporator unit in the back area to keep those folks cooler.
A thought: I know the Brits have heater problems in the Wolf Defenders in Arctic areas, and fit a drop down flap behind the front seats to confine the heat to that area only. Maybe in your case, a sheet of heavy clear plastic might be worth a try for an inexpensive solution to the cooling confinement.
I thought you were going to travel in the Middle East and Africa. Are you now adding Canada to the list, or are you referring to difficulties in crossing borders on your original itinerary?
Cheers.
nice find.
regarding your ac all m.e. 40 series 2F's ive seen with ac have it on the passenger side under the p.s. pump. AFAIK 60 series 2f's were set up the same, check out the local boneyard- youll probably have more luck finding a 60 with ac. hopefully your evaporator will still work- if not theres a good aftermarket one available here with an excellent fan- better than stock, and fits like a glove. cost about 350 riyals. works great for me on my 84. id include a pic but shes in the shop at the moment. i can post up when i get her back if you like.
good luck
and here are a few updated pics...
things are very slowly moving in the right direction - with a new ARB 'inspired' bumper, brush guard, INTI 'inspired rack', and rear light cages, its starting to take the form of an African adventuring machine...
currently i'm working on heat/sound proofing, fabbing a hannibal 'inspired' awning, and rear storage/sleeping platform...stay tuned...
