ok the background:
hj45 troopcarrier, 1980, drum brakes all round. got sick of adjusting the drums every other weekend.
converted to disks using FJ60 knuckles, new calipers, pads and rotors.
i pulled the front one of these valves
https://forum.ih8mud.com/40-55-series-tech/185090-what-these.html
shown in post #10, from the front circuit, due to reading poser's/others opinion in this thread that they will cause drag.
https://forum.ih8mud.com/40-55-series-tech/267373-how-remove-residual-valve-disk-brakes-2.html
master cylinder is a factory replacement for the hj45, with a single resevour, but dual circuit.
i followed the bedding in proceedure outlined by the brake component manufacturer.
the brakes probably have 500 kilometers on them now
now the problem is, i have decent stopping under normal conditions, BUT under emergency stopping conditions, the pedal gets to the point of no more travel (not the floor, about 2/3rds of the way through the pedal travel, normally where the drums would lock up), BUT the troopy just "slows to a halt". i cannot lock up the front brakes on dirt or pavement. rears will lock with alot of provocation
i have bled and re-bled the system. the pedal has no "spongeyness" to it. pedal feel is excelent. the booster is doing it's job (disconnected is much worse, and the hold the pedal/start the car test shows it works).
the master/lines are not leaking. all front rubber hoses are new. no kinks in the metal lines.
i have pulled the lot apart and hit it all with brake cleaner to ensure i didn't get grease/oil/crap on anything. i have rechecked caliper bolts for any that may have come loose. all 4 pistons on each caliper appear to be moving freely.
is there anything else to try? i'm about at the stage of putting the valve i mentioned earlier back in to see if that helps, but i'm not holding out much hope it will.
