Weber Question
Discussion in '60-Series Wagons' started by jeverich, Feb 17, 2009.
  1. jeverich
    jeverich
    355
    May 4, 2008
    Point Judith Area, RI
    Just did valve adjustment - all are within spec...
    Getting a SOLID, 21 in Hg of vacuum at idle.
    Weber 38
    However, truck idles fine (750RPM) at initial startup. As soon as truck reaches operating temp, idle does not go below 1000/900RPM. I am thinking that it is a choke related issue - already checked that electric choke is getting voltage - it is.
    Maybe manually cycling the choke?
    I'm very very happy with how she's running right now - and really happy with the vac. numbers.
    Maybe I'm just stupid!
  2. wengejor
    wengejor
    1,235
    1
    Oct 14, 2007
    MidWest
    Sounds like it's working properly.
    Set the idle after it is fully warmed up to like 750 rpm.
    To use the electric choke on cold mornings, turn the ignition on to power the choke, press in the pedal a few times to set the choke, then crank it over. With choke set it'll idle at like 1500 rpm until you "release" it with the pedal (quick press) after a few minutes of warmup. I do this every morning.
    It'll probably idle a little low after chock release (like 550) until it fully warms up then it'll return to the 750.
    hope that helps
  3. lehiguy
    lehiguy
    3,792
    25
    Mar 18, 2008
    Lehi, Porter Rockwell's home town
    Setting the idle speed should be done on a hot engine. Then adjust the choke to compensate for cold operation. All of this assumes that your idle mixture is correct and there are no vacuum leaks. If it gets fairly cold where you are, I highly reccomend a fluid heat riser if you don't already have one. It is virtually impossible to get a carb right to work in very cold weather as the venturi effect causes an even greater drop in temperature and the fuel drop out rate goes through the roof.
  4. FJ40Jim
    FJ40Jim The Cruiser Whisperer SILVER Star
    10,352
    Media:
    1
    2,731
    Sep 26, 2003
    Lancaster, Ohio, USA
    Have you tried adjusting the idle speed?
  5. JohnnyC
    JohnnyC Long ago TLCA# 2231 SILVER Star
    15,737
    Media:
    130
    Albums:
    10
    4,432
    Jun 17, 2005
    Albany, NY area
