Fjforty: Yes if you pump the throttle it will rev up and run OK, but once you let the throttle go back to normal, it dies.
Pin_Head: When the engine first turns on and is running OK, the vacuum is rock solid at 19 inches, then once it starts to warm up and flaking out, the vacuum bounces all over the place, drops proportionally as the engine dies.
I used the vacuum line off the power booster.
I also installed a RemFlex, badass intake/exhaust manifold.
I can see how it looks like a vacuum leak, and hell it might be...
Oh, here is another little something the accelerator pump is leaking gas. Can this cause these issues?
