Water pump/radiator replaced - dashboard light issue
Iowa
Hello, a friend replaced for me the waterpump and radiator today and now my passanger airbag light is on. I know it makes no sense, I cannot think of a connection.
The only think that might caused could be the fact that I connected a power generator to remove the battery connectors to clean them - I’m not sure if I have the radio codes and I was trying to avoid a trip to a dealer in case I need the radio codes after I disconnect the battery.
Could you guys speculate what would cause this light on? I don’t have access to a techstream cable or a PC laptop to test.
Thanks
I honestly can't think of what would cause the SRS to pop from swapping a water pump. I would swing by a Toyota dealer or Autozone (or equivalent) and have them clear the codes and see if they pop up again. However, usually with SRS codes, if the issues is resolved, the code and light will go away immediately.
