so, understanding the effects of how diesel injection timing has an effect on egts, ie. advancing timing can reduce egts seen on an egt probe as more of the burn happens in the cylinder, vs. retarded timing increasing seen egt's as more of the fuel is still burning as it enters the exhaust manifold, i wonder if some of the reduction in egt's (using water meth) are happening because of the possible effective advancing of timing using water meth....
some of that has to be the water for sure though, especially if using just water.......
thought food
its a good debate anyhow
im going to experiment with it either way, it is just too interesting to me not to do it, very little meth will be going through it in any event, my egt's on the highway need a bit of cooling and im not wanting to turn down the fuel ( or up the boost), she just needs a wee little squirt me thinks
then i should be able to not have to get off the throttle on hills
aem v3 kit on the way.....
