water in oil
I keep getting water in the oil. The plugs look clean,no smoke. The compression is between 160-175 and I can't find any other leaks.I checked with the search window and couldn't find anything close, any suggestions where to look or what may be causing this.This is a 1971 stock F motor as far as I know.
Leak.......
Head gasket, cracked head or freeze plug...........
Myself, being its a F motor, I'd just throw in a can of K&W Block sealer........
So, does that K&W block sealer really work? I'd like to try it in a SBC 383 that was clearanced for the crank a little too much.
