Hey Y’all,
Long story short, I pulled my weathertech cargo floor mat the other week, and a patch under the mat was soaked. Nowhere else was wet at all.
Found this link, noticed I had the same XM radio antenna, and the cable was routed improperly. Had the shop replace the weather stripping and route the cable properly while the car was in for the evaporator core.
I pulled out the carpet and padding, and dried it.
after some rain, I went to check the back for anymore leaks before re-installing.
turns out the shop did not run the cable properly, and I’m getting water pooling in the bottom left and right corners of the weather stripping in the interior. Car is going back to the shop on Monday for them to fix (hooray for 3 year 36k mi warranty on their work).
however, I noticed some water pooling below the plastic trim, on the right side of the cargo bay.
I can’t pull the trim because the bolt for the seatbelt won’t budge - it actually ripped my 10mm socket.
anyone know what that bolt is / have thoughts about how it could be so wet? From the looks of that rust, water has been in there for a while.
Any suggestions on removing the bolt that holds the seatbelt in place?
