how long will that work for?
Wow, super fast now on IE7!!!!!!!!!!!!!!
Too save a little time when typing those commands, do the first one make sure its correct hit enter. The prompt will come back up, now hit F3 this will put back up what you previously typed. Move the cursor over the text that has changed and hit enter again. Repeat once more.
Cheers
Cheers
Ok IE users (or other people having problems)
I NEED YOU TO TRY THIS
You'll see my username on here because this is a static page I saved and edited, but it's just to see if it still loads slowly for you. Please click it and let me know.
www.nate-online.com/mud_test.html
it's still slow on the ie7 for me, but the ie6 machine is as fast as firefox
Try clearing your cache. You may have the scripts stored in cache.
which linkGladly, can you access this link in IE7?
which link
hope that helpsOk, windows users here is a quick fix until woody gets back:
Open a command prompt (Start->Run... type in "cmd" [without the quote] and hit Ok...) and run each of these one at a time (be sure to type them exactly. if you make mistakes the fix wont work)
To be fair to woody, blocking ads kills his ad-revenue and makes running the site more difficult. However there is no point in keeping crashing ads that make the site unusable, so I don't feel too terrible explaining how to block the offending domains.Code:echo 127.0.0.1 yieldbuild.com >> %SystemRoot%\system32\drivers\etc\hosts echo 127.0.0.1 ads.digitalpoint.com >> %SystemRoot%\system32\drivers\etc\hosts echo 127.0.0.1 tag.contextweb.com >> %SystemRoot%\system32\drivers\etc\hosts
edit: To explain what that does.... every operating system has to look up the IP address of a domain name when you request a page (for example: no computer can access ih8mud.com directly. They must first query a nameserver for the IP address where the server for ih8mud is located. In this case it is actually 204.10.140.65) before it can connect to it. Windows will check what is known as the "hosts" file first though (before it contacts a nameserver) to see if the domain is listed there. These commands add lines to the hosts file which tell windows that the IP address of the offending domain is actually your own computer Now, obviously you aren't the host, and windows knows this but it never questions the hosts file, so it simply cannot load the ads. It's a crafty way to get around the ads and these changes apply all over windows, not just to IE.
