Parting Out Washington: 1991 3FE and A440F with 180k miles
Redmond, Washington
I have a 1991 LC 80- with the 3FE installed. 4 push-rods broke and are lodged in cylinders 5 & 6 I think. The motor is seized and will not crank over, but still has many good parts. I also have the A440F transmission which leaks a little fluid but works fine. Let me know what you need and I can see what I can do. I
I could use the dashpot assembly (Part ID 22202 - upper right corner of diagram) and the idle speed control valve (Part ID 22270 - center left of diagram).
How much for the AFM (air flow meter) and IAC (idle air control valve)? See pic
Please PM me with prices shipped to 93065
The idle control is one of the two parts I asked about. It's Part ID 22270 in the diagram (the one in the small blue circle in @Dynosoar's post - same part).
Sorry, I'm new to selling things on IH8mud and told @Dynosoar's he can take the idle control. Did you want the idle speed control valve Part ID 22270 for $20.00 + shipping?
Those are the same parts - idle control is 22270. That would be great if you have a second one. And how much for the dashpot 22202?
I'll be removing as much as I can this weekend and will get more pictures. I'm also keeping a list of parts folks have wanted and will finalize soon. Sorry still getting use to ih8mud classifieds
Hi there. I am doing the same as you. How is your LS swap working out so far?
So I changed my mind after scoring a 2UZFE for $250 This might be cheaper if I take my time, but not sure what to do at this point.. have you started your project? What is your budget for this?
I picked up a low km 5.3 engine 4l60e tranny and transfercase out of a 1999 Silverado. I am just starting to pull the engine and tranny out of the 80 and I will send the 4l60 transmission in for a rebuild. I am going to use a adanced adapter to a landcruiser split tcase and either a fitech or a holley Dominator EFI ECU.
