Dusty, I can't get a riser the correct length for a 4" lift in there that will clear the cross member on full compression. I actually cut the steel and placed it in the axle pocket and it's a no go. Now I could bump stop the axle so it would fit but that's counter productive to what I want.
I drew the axle and frame up in AutoCad and by raising the axle mount by 4" you raise the point of contact by the tire by 2". How are you determining it's worse?
you must be right. you have the oe axle and frame sitting at your house. but i can tell you that if you move the entire setup to the way i have it you will have no problem
I am figuring the "worse" case scenerio to be with the pass side rear at full droop with the driver side rear at full stuff. i immagine this to cause a greater problem if we move the axle side panhard mount up. I need to know this. perhaps you could post up your cad mock up?
I'm not about to FUBAR my rear axle just to get a panhard riser under there. The drawings are gone so you'll just have to trust me on this one. By raising the axle mount you are raising the axle's rolling center point by half of the amount you raise the mount. So a 4" riser increase the rolling center by 2".
Wouldnt you A frame the rear, with all that fab, to keep a better roll centre than keep the panhard ?
I want to replace the bolt that came with the kit...
is there a reason why we don't fab a bracket for the panhard in the center of the axle and use a bar that is half as long?
So you can either trust what I posted or wait for your bracket to understand what is going on.
This whole thread was about replacing the bolt that comes with the kit with a factory equivalent.
Luckily I've been cleaning out my garage and stumbled on a box of bolts from about 6 years ago and they had a set for the rear mount for our front control arms. Right size, class and thread pitch for this repair.
Toyota part numbers are:
bolt = 90105-18006
nut = 90170-18007
washer = 90201-19011
if you look at the bolt the shaft has worn away and it was sloppy in the bushing's hole. The bolt also had loosened some. Right now I'm in the middle of making a raised bracket for the axle and eliminating the drop bracket completely.
Tank! Love the seat extension BTW. How did this bracket turn out. I can't find any front or rear panhard drop brackets for my '97 LX450. Planning on a 3' HD OME lift (J springs and sport nitro shocks) but realized at last minute that i should have all future added weight (front and rear bumpers and sliders) on truck prior to lift or i would have some unwelcome handling characteristics. Brackets seem like a better fix because they keep a closer to stock panhard angle. Also, since I on the subject did I see some state that a front panhard drop bracket would interfere with the pitman arm(?)(I'm a coffee roaster, not a mechanic). If this lift is seriously only 3", after a LSPV adjustment do i need to worry about other mods.
Please help, "worried and obsessed" in Sonora.
And the riser is a dead project. To build it correctly with a 4" rise it will hit the cross member above it. So I buttoned up the panhard with the new hardware and am calling it done@NXLANCY did landtank ever make this lower axle raised mount?
