SOLD WA: 1F Engine and parts (some 2F)
Skreddy
Spokane, WA
Bunch of parts from a few different engines. Will ship any of it anywhere at buyers expense. Open to offers. I can clean up any of these parts to for small fee, including sandblasting.
Updated 10/20
Free F engine block from 1970. Had stuck pistons from some rust. Needs honed or bored.
Otherwise….
SOLD 6 pistons and rods, need clean up $50 (from above pic)
SOLD 6 pistons and rods from running 1F that had cracked block (I think standard bore) $50
Main caps from the cracked 1F with shims $40
2 oil pump and pickup assemblies $30 each
ONLY SMOOTH COVER LEFT: 1 from 2F with indent for distributor SOLD $30, other two are from F, 1 has pcv port in cover SOLD, other doesn’t $20 each
Also F valve cover $20 SOLD
Oil fill tubes for F, 1 with pcv and 1 smooth $15 each
2 timing covers $15 each
Head from above engine with rocker assembly and head bolts $50 (head on left)
Head from a running F that block was cracked $150 (head on right)
Rusty 2F rocker assembly. Crusty but they all move so should clean up. Was from a 75 FJ55. $20
Pushrods 2 sets $20 a set (set in upper left are gone)
F remote oil filter mount (intake mounted) $30
Oil pan $30
Thermostat housings. 1 just bottom SOLD $10. 1 off F engine with thermostat inside $40. 1 off of early 80’s 2F (I think) with 4 bolts and oil cooler port, no thermostat $50
Single groove balancer/crank pulley $10, single groove water pump pulley $10, crank claw nut $10, crank timing gear (2) $5 each.
Intake manifold from F engine. $50
F engine air filter bracket $20
F engine fan, no apparent cracks $10
EGR from 75 FJ55 2F. FREE because it may be no good?
Front F engine mounts $40 pair (2 pairs)
3 speed bellhousing $60 including dust shield and side dust shields (will separate)
F engine lower alternator bracket $10
Clutch fork from 3 speed (stamped) SOLD $10
Cast clutch fork from ? With throw out bearing piece $15 SOLD
Flywheel for 3 finger clutch, needs surfaced. $40
Dibs on the dented side cover for now. Gonna keep browsing. - Looked through the rest and nothing I can't live without at the moment, I'll just take the dented side cover @Skreddy
I’m interested in the lower thermostat housing and the stamped clutch fork
I’ll pm you…. Wait a minute….. I’ll call your shop line tomorrow morning.
F Valve cover and 4-speed clutch fork/throwout bearing (the $15 one) please.
I’ll update the thread and message people in the morning. Wife had friends over and I coped by having a few whiskey lemonades so I’m not messaging important business until tomorrow….
No…. But I have 2 single line fuel pumps. That’s just as more good.
Can you pm over some pics please? I'm going to look for a backup to stash in my parts bag.
That way I don't have to use a wader patch kit in case of emergency!
Pm incoming
Got your message. Sorry I haven’t called you back. Hopefully the parts are still available. Also interested in the 4spd rear plate, but haven’t decided what to offer you for that.
Still set aside for you when you’re ready. Rear plate is still available too.
