VSC (Vehicle Stability Control) (3 Viewers)
Kid
Sedona
Got new tires and left the shop with this light on , 4 days later , it's still on .
What am I to do ?
Thank you in advance
Stop at your local advanced auto parts or similar parts store and they can pull the code for free.
Sounds like a wheel sensor wire may have been damaged when putted Gx on the lift, damaged putting a wheel back on or just by coincidence one failed.
Get the code pulled.
I was going to suggest ABS sensor
AT O'Reilly's . nothing came up .
He said it checks only engine , ABS not part of engine , I guess
I don't have any insight in to the error itself but, If the light won't turn off, I'd buy one of these to pull the code myself:
I know Techstream can be a little hard for some people to set up. I hated having to have a laptop for it so I grabbed one of these and it will pull the all the codes that a regular OBDII reader misses. Mine has reprogrammed my TPMS for my new wheels and helped me test my sunroof motor after it wouldn't close. It also emails you a report with all the errors so it's easy to look them up.
Example:
Details:
A much better option is to get a OBDLink OBD2 dongle and the free app for your phone.
It will tell you everything, along with real-time information on all your systems, e.g.: temps for: engine, trans; tire pressures and temps, every code your GX could possibly throw and an explanation of what the code is.
There are several of us who use this product and it's a ⭐⭐⭐⭐⭐ for me.
I have that too. I love it but I hadn't ever tried to pull codes beyond engine stuff. Just went out to see if I got the same codes and it looks like it has them. Nice. The Launch tool has more function in that it can actuate motors, program TPMS/Keys and run diagnostics that I had only seen in techstream but for this, usage the OBDlink would be perfect. Plus I love being able to watch AT temps with it.
