Hi guys, finally got her back and running. Thanks to the guys at Proffitt's for slipping me in their busy schedule. Now the fun begins, I have some bugs that need working out. First a little background. I have an '03 motor that I mistakenly thought was an '02 motor. My computer and harness were made for an '02. Shouldn't be a huge problem, but I think some of the trouble I am having may have its root there.
First, no signal from the 02 sensors. I am only using ones for before the cats, cause there are no cats and only 2 02 sensors. I have figured out after replacing my used ones that '03 sensors ground at the computer, '02 and earlier ground elsewhere. So I have some '00 02 sensors now, that howell sugested using, but still no signal.
Next, surging idle. The code reads fast idle, and the surging may have to do with the lack of 02 signal and nothing with the code. I changed to a manual throtle body. When I did this I plugged the tube coming off the upper side of the throttlebody itself and used the one that is on the intake because it was already hooked up. it looked like it shouldn't make a difference, but I don't really know.
Last, Again this may have its root in the lack of 02 signal, but it will cut out when I really get on it, and blow a cloud of unburned gas out the back. I thought it was a wide open problem, but it has done it at 3/4 throttle too.
FYI, Vortecs rule. even with a few bugs to workout this thing huals ass.
