- Joined
- Jul 8, 2013
- Threads
- 65
- Messages
- 3,082
- Location
- New South Wales, Australia
- Website
- www.completecruisers.com.au
I torque to 105 ft lbs, thats a bit higher than spec but seems to workwhat's the proper torque?
So here's what I've done so far:
1. visually and manually (using hand to see if there's movement in anything or bolts holding things on) checked u joints, bushings, damper, steering linkage, leaf springs. Nothing except the tie rod link was loose to the touch and none of these has been worked with since I've owned it. The tie rod link (that's what I'm calling the link between the steering arm and the tie rod; see pic below) was very loose. It rotated maybe 1/2+ of a inch. I haven't tried tightening the castle bolt to see if it actually cinches down. I have my doubts but I'll check.
2. checked for wheel bearings being bad. It was just the wiggle test. The wheels had no vertical movement and only a small horizontal (3 and 9 o'oclock). The whole inner hub tended to move with the wheel but as I say, it was only a very small amount (maybe 1/8+ of an inch).
Have yet to check on:
1. tire balance
2. wheel alignment
3. exact angles of drive shafts but rig hasn't had a lift or transmission switch so not sure why that would matter.
Tomorrow, I'll take it to my mechanic who isn't familiar with these rigs, but I'll share with him what you guys have told me. I'm including various pics of the steering links and such below, so if anyone sees something I haven't because I'm a uneducated observer (some of the terms you guys use are like a foreign language to me, please hollar. Thanks to all.
This first picture is of the steering link that has a lot of play (the 1/2+ inch)
same thing but different angle of the first photo
This is the other end of that link toward the front of the rig
You had it twice? How did you figure it was the rims?I had death wobble on my 77 FJ-40. Checked everything.
It was my bent steel wheels...keeping my tires out of balance.
It happened around 35 MPH if I hit a bump.
Had bushings replaced, everything in the front end freshened-up and re-torqued. First drive...35 MPH, hit a railroad crossing...death wobble.
Replaced wheels, not tires. Death wobble gone for good.
Sorry, I should have put those back on before I took the pic. They're on now. thanks for mentioning it. What am I looking for if I lift it and have someone turn the steering wheel--just looseness at any of the joints?cant tell what it is but one of your pics shows a missing castle nut and cotter pin at a link end...
in addition to trying to move things by hand you can lift front end off the ground and watch as someone turns the wheel back and forth. As things reverse direction you can see if there is movement at each connection point.
So how did you know it was the wheel rims--matter of only thing left to look at or?Sorry if my post was confusing:
Had death wobble. Addressed total front-end refresh. Did not fix.
Fixed.
It's a process of elimination. Start with the easiest and cheapest. When you get your tires balanced be sure the tech makes sure your rims are not bent. Do what erics mentioned. The only thing I would do different is have someone shake the steering wheel back and forth, while the wheels are on the ground. Sometimes components need more resistance to show if they are bad or not. Everything needs to rotate evenly, no wobble. The tierod/link rotation is normal. Watch the rod ends. Watch where the knuckles rotate, Watch the relationship between the spring and the spring perch. There should be no movement. The shackles will twist slightly, excess movement is bad. Look at the steering arms and the bell crank, does the shaft wobble, is the unit loose on the frame? Etc. Then jack it up and check wheel bearings and knuckles, and double check the previous items mentioned.
