Hi Wedgetail
Like you looking to put a H152f (0.75 5th gear) into a HZJ105R (After Market Turbo) - so doing lots of research.
Have you progressed on this proposal ?
I would be interested to work with you in this ?
1 main question for me is which GBox gearshift to use and any tunnel mods to fit it ? , clearance in the cabin ??.
For databases
I have managed to find both the pre and post 2017 H150/152 for the VDJ 7#R
Using whenever possible the AUS or in absence the GEN - country codes
Using the HDJ78R or VZJ78R = Troopy- LX -versions
The sites Ive been using are
The best site for all vehicles (but dosent seem to have any H152 - post 08-2016 parts) always states 01- 2007 --->
Transmission and chassis for Toyota Land Cruiser with VDJ78R
toyota-general.epc-data.com
For what appears to be post 08-2016 H152 parts ? - but its not clear
Looking for genuine OEM Clutch Housing & Transmission Case (Mtm) for 2016 - 2018 Toyota LAND CRUISER VDJ76 (General sales region, , 18025362-936472)? Check on MegaZip at discounted price from manufacturers' warehouses in Japan, USA, UAE. Detailed diagrams & catalogues. Worldwide shipping. Easy...
www.megazip.net
For individual parts - Im not so sure that are the H152 - it just says from 08-2016 -->
Part # for the VJD7# gearbox H150f = 33030-60B91 / H142f= 33030-60C50 (but all references only show the H152 from 08 -2016 up to 01-2018 thereafter it disapears ??) - no Gbox apparently !! - what gives ?
Here are the part # ive deducted so far - and in Red the BOM
Note :- I intend to keep the fulltime box - and convert the input gear to the H box output shaft splines
I originally intended the H151 - but my RPM increases by annother 128 RPM @ 100k - due to the 4.3 diffs
With the H152 - I drop 263 RPM ~11%
Description | HZJ105R | HDJ78R
H150f | VDJ7#R
H150f/H152f | HDJ100R
H151f |
FLYWHEEL SUB-ASSY (inc Ring gear) | 13405-17050 | 13405-17020
($650 USD) | | 13405-17020
(inc 1HZ) |
BEARING (FOR INPUT SHAFT) (Spiggot) | 90363-12010 | 90363-15017 | | 90363-15017 |
COVER ASSY, CLUTCH (Pressure plate) | 31210-36160 | 31210-36240 - to 11/2001
31210-60210 -From 03/2006
SUB both above - 31210-36320 - to 01/2007 | | 31210-60210 |
SUB | | | | 31210-36320 |
DISC ASSY, CLUTCH (Clutch plate) | 31250-60283 | 31250-60342 - to 09/2001
SUB- 31250-60343 - to 08/2005
SUB- 31250-60390 - to 01/2007 | | 31250-60343 |
FORK SUB-ASSY, CLUTCH RELEASE HDJ100..5F | 31204-36110 | 31204-36142 | | 31204-36142 |
SUPPORT, RELEASE FORK | 31236-35030 | 31236-36060 | | 31236-36060 |
BOOT, CLUTCH RELEASE FORK | 31126-60050 | 31126-36090 | | 31126-36090 |
SUB | | | | |
BEARING ASSY, CLUTCH RELEASE (Throwout) | 31230-60200 | 31230-60210 | | 31230-36210 |
CYLINDER ASSY, CLUTCH RELEASE (Slave Cylinder) | 31470-60280 | 31470-60290 | | 31470-60270 |
HOUSING, CLUTCH | 31111-60321 | 31111-60290 | N/A | 31111-60290 |
H152f gearbox (includes Bell housing and RETAINER SUB ASSY) | N/A | 33030-6A570
$4697 USD | 33030-60B91 / 33030-60C50 | 33030-6A550 |
Gearshift Assy (Boot /Lever/Bush) | N/A | 33530-60480 | 33530-60480
(US $ 89) | 33530-60370 ? |
Gearshift Assy (RETAINER SUB-ASSY, CONTROL SHIFT LEVER)
Comes with gearbox | N/A | 33506-60090 | 33506-60180
(US $72) | 33506-60100 |
TRANSFER ASSY (Transfer Case complete) | 36130-6A050 | | | 36130-60821 |
Alternate | | | 3613060820 | 3613060820 |
Transfer Case input housing | 36103-60290 | 36103-60220
36103-60240 (W *ELC) | 36103-60291 | 36103-60290 |
Transfer Case -GEAR, TRANSFER INPUT | 36212-60131 | | | 36212-60119 |
GASKET KIT, TRANSFER OVERHAUL | 04362-60050 | | | 04362-60080 |
Transfer Shift Assembly | Keep original | | | |
H152 Gbox internals comparison | | | | |
Front Housing Gbox | | 33111-60220
(untill 01 2003) | 33111-60310
(from 08 - 2016) | 33101-60091
(untill 01 2003) |
SUBsitute | | 33111-60260
(2003 onward) | | 33101-60130
(2003 onward) |
Input Shaft | | 33301-60060 | 33301-60080
Same Part Pre and post 2017
(US $336) | 33301-60060
(US 241) |
Input Shaft bearing retainer | | 33131-60070
(US $ 70) | 33131-60100
($US 105) | 33131-60070 |
Input Shaft bearing oil seal | | 90311-35023 | 90311-35023
(US $ 3) | 90311-35023 |
Input shaft main bearing | | 90363-50007 | 90363-50007
(US $44) | 90363-50007
(US $58) |
Main bearing retainer clip | | 90520-99010 | 90520-99010
( US $ 2) | 90520-99010 |
Input Shaft Snap ring (rear of bearing) | | 90520-45003 to 08 | 90520-45003
(US $2) | 90520-45003 to 08 |
Input shaft needle bearing | | 90361-08004 | 90361-08004
(US $ 1.00) | 90361-08004 |
Output shaft (mainshaft) | | 33321-60140 | 33321-60140 ??
(US $ 266) | 33321-60140 |
Terrain Tamer kit (Counter Shaft and 5th Gear) | | 33421-MOD79K
$A - 1075-00 Aus | | |
