Greetings, all.
During the spring I made a cross-country trip in my '98 Cruiser. The vehicle exceeded all my expectations and got me out of more than one jam on the muddy trails of North-Eastern Nevada. She took a beating for the whole two-month trip, but got me home and dry without any problems.
Recently, I've gone over the vehicle and changed out some seals (rear pinion and axle) and a front axle. I thought I was getting off lightly until she started idling rough and spat out the dreaded P0300 codes. It read P0300, P0302, P0304, P0306 and P0308. The entire passenger-side bank was misfiring. After a couple of minutes idling, I could see fuel dripping from the exhaust joint just after the muffler.
I suspected that the valve timing was off so I removed the left and right timing belt covers, set the crank shaft to "0" and noticed that the passenger-side cam gear was retarded by two teeth.
My question is, is it possible to advance the passenger-side cam gear two teeth by somehow relieving tension on the timing belt? I really don't want to remove all the components necessary to change the timing belt and was wondering if there are any short cuts or tricks to advancing the passenger-side cam gear to its proper position.
Thanks.
Thanks.
