Good afternoon all.
100,000 miles ago I head my '78 head worked on. Now it's blowing some smoke when I let it idle a bit then I accelerate. So I began replacing the valve stem seals with the Fel-Pro SS27504 ones. The machine shop put the later 2F seals, which I am finding out are the good ones.
Now I'm getting a bit confused as the manual shows that a valve spring seat goes between the spring and cylinder head. My setup consisted of the later 2F valve stem seal (which I figure acts as the seat and seal), then a washer with grooves on the bottom of it and then the valve spring. Now that I am putting the Fel-Pros on, I have no seat and only the washer.
Questions: do I need the seat? do I need the washer? If I need the seat, can I just cut the used valve seals and use them as the seat? If I use them as the seat, then do I really need the washers?
When I reassembled by just putting the washer it looks like the spring will just dance around.
Thanks all.
Thanks all.
