May 1971 3 speed.
I can usually find the answers I need here, but this problem has me baffled and I can’t find a similar problem in another post. At approximately 20 mph, give or take 2 mph, I hear a sound like valve clatter/clicking. No noise before or after. No noise when running up rpms while stopped. I cut the engine while the noise was occurring, and it ceased. So it seems to be engine related. I use Delo 400 15w-40 and it’s nice and clean. If it is sticky valves (only at 20?) it’s not from neglected maintenance. I have adjusted the valves twice, but I’m going to do it again and be absolutely sure that’s not the problem. I have moved the timing all over the place (say from 7BTDC to around 20BTDC; fyi, I’m at 3500 ft) no meaningful change. I have disassembled the (retard) distributor and cleaned and lubed the mechanical advance weights, thinking they might be hanging up around 20mph causing a retarded timing issue. No change. I’ve disconnected the speedometer cable at the cluster, thinking that might be the problem. No change. I’m out of my depth as far as other possible causes. Any input will be appreciated.
