Valve Grind Kit
Atlanta, Ga
Does anyone happen to know or have a list of all the pieces that comes in a valve grind kit? Thanks
You failed to state which engine, I will assume 1FZ:
Kit # 04112-66035
Head Gasket
Valve cover gasket
Spark plug tube seals
Intake manifold gasket
Surge tank (plenum) gaskets
Exhaust manifold gaskets
Exhaust flange gaskets
Throttle body gasket
Valve seals
Injector seals
PAIR valve gaskets
Bypass pipe o-rings
Fuel pipe-to-rail gaskets
Chain tensioner gasket
Does not contain:
Distributor o-ring
EGR valve gasket
Heater return pipe gasket
Is there anything else you would need to do the head job?? I can think of new head studs, but I guess that isn't a must.
The list of "sundries" is a very slipery slope.
As Dan acurately put it, the list of while-you-are-in-theres can be extensive. Along with the parts that Dan suggested, I would also get a FSM - either digital (look up automatic FSM download) or a hard copy.
Karl
