In this case, the valve face and valve seat will be the highest wear points. This will allow the valve to sit deeper in the head as it wears (closer to the top of the head than the bottom) to a very very small degree. this will reduce clearance between the cam lobes and the valve shims/followers. Not much not much at all. But by a very small amount over time.I’m not understanding about how wear will create tighter clearance. Wear on the shims sure. But wear everywhere else will cause a looser clearance which In turn causes noise. Tighter clearance is generally caused by a bad rebuild
Mark...
