- Year
- 1978
- Vehicle Model
- 40 Series
- Mileage
- 1000
- Color
- Green
- Outside Link
- https://www.classiccars.com/listings/view/1631910
I have a detail 3rd Party Inspection by Lemon Squad I can share with any prospective buyers!
Recently Reduced to Sell $19,000 OBO !!!! Great Retro Ride! lots has been done, some more additional needed Text 213-999-6907 for additional questions ( don't call please because I am in meetings all day ). It needs some work so thats why it is priced where it is ….
* All the Smog Equipment has been removed by a prior owner, so cannot be registered in California (please check your State to confirm local regulations)
Clean Title !
Odometer is wrong due to the last owner replacing the console and it came to me with ZERO miles. Currently has 561 miles since I got it ...so who knows how much it really has
Drives well, starts easy and moves smoothly. Not looking to profit, just break even on what I put into it and let someone else finish the restoration.
PROS:
Clean Title !
PROS:
- Front / Rear Differential Rebuilt
- Steering Stabilizer Replaced - Old Man Emu Brand
- 4 New Pro Comp Shock Absorbers
- New Clutch Kit - OEM Aisin
- Gear Box Rebuilt
- Center Arm Shaft Repair Kit - Spector Off-road Kit
- New Oil Pan / Gasket Installed
- New Battery
- New Steering Gear Box
- New Alternator
- New Spark Plugs / Cables
- New Distributor Cap / Rotor
- New Starter
- New Fuel Pump
- New Radiator
- New Brake Master Cylinder
- New Clutch Master / Slave Cylinder
- Valves Adjusted
- New Carburetor: EBay OEM Reproduction Item # 392840252565
- New RetroSound Stereo - Bluetooth Enabled / front speakers / rear box speakers
- Barely Used Tires
- Interior, Undercarriage, Engine Compartment is very clean
- Windows roll up and down
- New windshield wiper mechanism replaced (still needs new wiper arm / blades)
- Fire Extinguisher
- Paint job is ok from a far, closer there are cracks, a patch job on the driver's door that doesn't match exactly, chips ... some rust in spots. 3rd party inspector said he thought thee was some bondo / filler under the paint causing cracks...
- Driver's side door works complete / Passenger door needs inside opener rebuilt + lock mechanism replaced
- Rear Door is slightly crooked / gap at the top. This is due to a missing gasket on the bottom of the hardtop.
- The locks on the driver and passenger door need replaced
- All interior ducts for heating / defrost ducts are missing
- Oil Pressure Gauge not working
- Drivetrain seems noise, but might be normal.
- Hardtop is cracked above front / passenger door - needs welded
- Some random leaks under drivetrain / a drip now and then
- Windshield Wiper mechanism replaced but wiper arm screw strips - arms need wielded to screw. Wiper fluid spray doesn't work
