Finally I got my rear 6 cil whole axle and front pumpkin off a 90's, t4r, 6cil, 4x4.
I'm going to replace the whole rear end which is wider and has bigger drum brakes, purchase spring perches, shock mount, u bolt kit and a spool. (that should be enough, right?)
for the front axle I got the front pumpkin off the same donor, will this be a direct bolt on?
my ride...
86 t4r, 22re with double timing roller from lc engineering, 6 cil master cil, 3" body lift from rockcrawler, 4" susp lift (front springs are the extra long), 33" mickey thompsons.
