UZJ100 Battery, Alternator and Ground Cable Kits - "Big Three Cable Kit"
Fourrunner
Syracuse, Utah
All cables are constructed from either 1/0 or 4 AWG tinned wire (marine wire). Wire is very flexible and jacket is resistant to moisture, oil, chemicals, and excellent abrasion resistance. Joints are sealed using mil spec heavy duty adhesive lined heat shrink to prevent corrosion.
Big Three - $65 shipped
4 AWG cable from negative side of battery to inner fender
4 AWG cable from the firewall to the intake
1/0 cable from the engine hook to the fender apron
All cables will include abrasive resistant sleeve material
Big Three Plus - $TBD (waiting on finalizing the design of the terminal extension and length of cables)
Big Three Cable Kit
Mil Spec Battery Terminal Kit (plus and minus)
Battery Terminal Extensions with hardware (working on finalizing design at the moment)
1/0 cable from the Positive Battery Terminal Extension to the starter
1/0 cable from the Negative Battery Terminal Extension to the intake manifold
Big Three Plus Plus - $TBD (waiting on finalizing both the Big Three Plus kit and getting the length of cable needed for the alternator)
Big Three Plus Kit
1/0 cable from the Fuse/Relay block bolted to the battery extension to the Alternator
Email me at mguisinger@gmail.com with questions or to place an order.
Very interested in these kits! I just started looking at doing this myself about a week ago
Excellent. I should have the first out this weekend and hopefully some pictures of the install and some user feedback. Let me know if you are ready or if anyone else is ready to try them out.
I've got two "test kits" en route to customers. Hope to get some feedback soon. As soon as that happens, we can certainly go that route. Will send you a message and we can discuss. If anyone else is interested in doing this, I am fine with this approach.
I need to replace my negative battery cable above all else. Which kit has that? The cable goes into a harness, where does it terminate? Is that the one you say terminates on the intake manifold?
That would be the big three plus. Yes, it terminates right next to the starter. I'm still trying to figure out the plus cable set. I hope to have something figured out by the weekend.
Have to pull the intake manifold to replace the negative battery cable?
I've got a cable for the starter and ground to the engine block (from the negative terminal) from a parts truck. It is quite the harness. Trying to track down the parts that will make it work. Hope to get some time on it this week.
Thanx! I'm definitely in for the Plus Plus kit
