Most folks that have done it have claimed improved stability and you’ll gain a bit of suspension travel. You’ll also have slightly improved suspension angles at the same amount of lift due to the longer arms.
forum.ih8mud.com
I am planning on using the new stock LCAs with the SPCs to fit 37s when my 35s wear out. It has been done before with significant trimming on fender wells and BMC from my understanding.I'm tossing the idea around in my head to modify OEM 200-series arm for 37s. To increase caster and clearance against the BMC/fender wells.
Anyone have used OE LCAs to donate to an experiment? If they are usable, even better.
Good info. If you don’t mind sharing, what size spacer or equivalent offset?I've got a pair, great condition, send me a PM and we can coordinate getting them your way. Only issue I had with the 37s with stock arms was hitting the frame and swaybar at full lock, running RW at a spacer. Spacer was needed to clear the UCA with the 12.5s
If you want, I am happy to send you these LCAs. Again the alignment bolts are seized and bushings shot, but if you want them, they’re yours.
I’m thinking of replacing mine while I am there and have a mostly new setup. Did you find any? I’ll send them to you for sure if I do.
Can someone remind me what oem cost is for a pair?
60k on my TC Uniball joints and they’re still silent.I wouldnt touch anything with a uniball, regardless of claims, with a 10ft pole. Squeaks and Maintenace are the norm there...
Others may argue, thats fine...
@TeCKis300 i will also have a set (old and worn) you can have if you'd like to butcher a trashed set before moving on to the ones from @nwfl4runner
Thank you but I got a set from @nwfl4runner . It's sitting in my garage staring at me waiting to be cut into.
I've said this before, but it's always surprising just how substantial these parts are when they're off the car. Giant monument of a part.
Yup. Lots and lots of miles and a good bit of wheeling on my Camburg Uniballs and they are still tight as a tick with no squeaks. I've never even cleaned them.60k on my TC Uniball joints and they’re still silent.
My Camburgs fell apart after 10K. Do not recommend.Yup. Lots and lots of miles and hard wheeling on my Camburg Uniballs and they are still tight as a tick with no squeaks. I've never even cleaned them.![]()
Well I don't wheel very hard so that's probably the reasonMy Camburgs fell apart after 10K. Do not recommend.
