I like to be proactive and have some knowledge before-hand when something happens and still be able to get my 100 home to research a fix.
Some things that come to mind:
1- If the Ignition switch rod breaks, how to get the 100 to start?
2- If the AHC fails?
3- If you loose a cylinder - ex: Fuel Injector, Coil Pack, blow out a Spark Plug?
This one my thinking a fellow forum member helped me with: If the spark plug is loose, remove it, replace the Coil Pack to prevent debris from entering, and disconnect both the Coil Pack and Fuel Injector, and Drive it home.
4- I'm thinking of putting together a Tool Bag - certainly a 10mm wrench and ratchet and Spark Plug socket. What other common tools?
5- I know these 100s are very reliable, but what other common issues one might encounter on the road?
