Good evening all
I am wondering if I can get some confirmation on my parts list for my timing belt job that I plan on doing in the next few weeks. I have searched the forum quite a bit, but due to having a 2007 LX 470 and it being vvti, there hasn't been AS many details on parts list for them (some differences I know). I know things like cam seals are not applicable unless more work is done, but some part #s are different it seems from earlier 100 series to vvti.
Background on why I'm getting the timing belt service done and looking to do a nice remove/replace on major components (while your there). I just got the car w/163k and one of the pulleys is on its way out (possibly idler pulley) and the last service for TB was supposedly at 100k but no receipts, the belt looks decent but i'd like to be ready to go another 90-100k starting soon on these components. The heater tee's look new, so im thinking these were replaced within past few years. I can always add them on, was thinking of using metal to prevent any future work. Really want to ensure whole serpentine belt assembly and all pulleys are replaced as I dont want to deal with messy bearings down the road.
Ordered and received so far from rockauto:
Aisin TKT021 : Timing Belt, Water Pump & Component Kit
Aisin THT015 : Thermostat
Aisin THP108 : Thermostat / Thermostat Housing / Water Outlet Seal
Aisin FCT075 : Radiator Fan Clutch
Aisin FBT002 : Radiator Fan Clutch Bearing Bracket
Aisin FIPG
The remaining parts I have listed are as follows, looking to get these all at one source. Was thinking either partsouq or directly from toyota (Mc George i've seen mentioned)
90029-07010 : Fan clutch lock nuts (4)
16604-50030 : Serpentine belt idler pulley (OEM)
90916-02585 : Serpentine belt
16620-0W101 : Serpentine belt tensioner assembly
12204-50030 : PCV Valve
90919-01210 : Spark Plugs (8)
9676-35035 : Water inlet housing o-ring (not sure if this is included in TKT021)
90311-A0001 : Front crank seal (is this part correct for vvti)
Timing Belt Cover Gasket Insert ? (saw this in cruserteq kit)
Oil cooler hoses????
Will also get 4g of zerex pink coolant? Not red right
Thoughts on doing oil change at same time or not necessary?
Thanks again everyone
Aisin FIPG
