Hi all,
TLDR version: ABS activates at slow speed (10mph) with very gentle brake pressure on smooth tarmac road. Why?
Full version:
I recently refurbished the front axle on my dads UK spec 1994 J80 (using the complete roughtrax kit, inner seals, new bearings etc). I carefully removed the ABS sensors from each birfield joint and placed to one side. Having now reassembled there is an off ABS fault that was not there before. The symptoms are:
ABS warning light illuminated for 3s at ignition on, then goes out. No further faults indicated.
When gently bringing the car to a stop, and I mean gently, the ABS will activate for what feels like the front right wheel for about 0.5s. I say 'feels' as there is pedal feedback, and the car pulls slightly left when it happens, which makes me think the right hand caliper is backed off by the ABS. It happens briefly at about 10-12mph, using very gentle brake pressure only. It also happens about every third gentle deceleration.
When it happens, it is not on loose ground, the wheel is 100% not locking. All tires are matching and of equal wear. The ABS seems to be triggering falsely for no reason.
If you try to get the ABS to work properly, ie find loose ground and hit the brakes hard, it works perfectly.
The only stored code is 31, indicating front right sensor, however I cant believe this is at fault as there is no permanent light, and it works fine when you want it to.
When I had the axle in bits to do the seals, I cleaned up the stub axle and toothed ring, and the sensor. All rings were sound, no cracks evident.
In trying to work this problem out I removed the sensor and inspected the ring with a torch. The valleys between the teeth had filled up with CV grease on both sides. This excess grease was carefully removed front both with a stiff brush through the sensor hole. Retesting the car after this, this cleaning up of the toothed ring has made an improvement, in that the false ABS activation is now for less time, but it still happens.
I have not yet tried swapping L and R sensors over to see if the fault moves, I ran out of time.
Has anyone any ideas?
Thanks in advance for any assistance.
Full version:
