OK so I have the Upper Manifold off getting the injectors cleaned. Other than all the vacuum lines and the VCV, which of this stuff under here should I be replacing while it's open. All? 1994 FZJ80
Yes I plan on doing the hoses, three way, check valves and VCV for sure. Was wondering if anyone has any insight as to the VSVs' life expectancy. I'll probably just do those too. Looks like the "Duty Vacuum Valve" and "Vacuum Valve Assembly" aren't available anyway.I replaced all the cheap stuff (like the three way) and vacuum lines because I didn't want to do it later and it's not expensive. Looks like some of your vacuum lines have been changed (the ones with "Hose #") and some have not (the ones with the #0 and #1 on them).
I just tested VSV per FSM and it passed so I didn't worry about it. I know VCV has a simple FSM test but I think there may be one more component test if I remember correctly. This is 97 LX450, may be different from your FSM.Yes I plan on doing the hoses, three way, check valves and VCV for sure. Was wondering if anyone has any insight as to the VSVs' life expectancy. I'll probably just do those too. Looks like the "Duty Vacuum Valve" and "Vacuum Valve Assembly" aren't available anyway.
Personally for me.... no way I will ever again use silicone hoses.Problem with silicone vacuum hoses is that they don't fuse or stick to the metal pipes/nipples so you may have to add a small hose clamp
for each end of that type of hose to ensure a tight fit. IME the OEM vacuum hoses last decades if undisturbed. IIRC the OEM breather and PCV hoses are FKM rubber (Fluoroelastomer) similar to Viton.
