ultragauge EM unboxing.
anyone using this thing? is using it dumb as rocks? any tricks?
I recommend downloading the manual and reading it.ultragauge EM unboxing.
i was going to do a youtube video...
yeah. i was being sarcastic. ; )I'm sure it will be utterly exciting to watch that.
yeah. thanks for the heads up. it’s quite a document.I recommend downloading the manual and reading it.
You're not supposed to be afraid of big books. The more pages it has, the more information is contained within. Therefore more knowledge can be gained.yeah. thanks for the heads up. it’s quite a document.
if anything isn’t straightforward or there are more tips i am happy to hear from folks. looks great. that owners manual is a tad dense though.
My understanding is that in Phoenix, emission stations take a dim view on anything that is plugged into an OBDII port, making it a reason to fail. Probably different elsewhere, but just a heads-up....I also think there was a replacement port that had 2 locations to plug in (90 degrees from one another) so you could leave it plugged in facing down and there would still be an available port for emissions inspectors, shops, etc to plug into. Haven't gotten to it yet so haven't done the research.
You can set up multiple “pages” of gauges to display in the UG. Mine are setup to cycle through the pages every 20 seconds.since this is the internet i somehow find i want to make a sarcastic comment about this despite despising this kind of snark. or about it being big /words/ or something. but i find myself 100% in agreement!
i think maybe the trepidation in looking at this manual is the amount of information i have just bitten off in terms of understanding something like this vehicle. i now see there is a lot of technical knowledge in here but really this IS part of the reason i bought it. other than my vehicle throwing codes of course.
i mean if i just use it to read engine codes that’s one thing. but to really put some effort into using it fully that is going to be a pretty hefty amount of work. not sure if that makes sense or not.
anyway, would anyone mind helping the noob with suggestions on what to set for the 4 or 6 gauges on the home screen on this thing?
maybe a heads up on othe gauges that would be interesting to keep an eye on for the late 80’ s series LX/LC? i mean if i know what to look for i also know what else i need to study up on to get some understanding.
THANK YOU
jonathan
Well, that's a good thing. Snark is my way and I believe I have cornered the market.since this is the internet i somehow find i want to make a sarcastic comment about this despite despising this kind of snark. or about it being big /words/ or something. but i find myself 100% in agreement!
In any case, regarding the UG, you need to think of it as just a monitor. No matter how you set it up or what your configuration is, it will not change anything on the vehicle, with the notable exception of resetting error codes.
Plug it in, let it discover the available gauges, and simply play with it. You can change the displays to your hearts content until you find displays that work for you.
Keep in mind that not all of the gauges listed in the manual will be available to you. Your ECU is from the early 90s and is first generation OBD2.
Personally, I think the 3 most important things to monitor are coolant temp, MPG, and battery voltage. Everything else is pretty much fluff IMO, but it is fun to look at, as long as it doesn't become a distraction from actually driving the vehicle.
I'm sure others will disagree, but that's what makes the internet a magical place of wonder.
I mounted mine on the lip of the dash between the vents. The cable runs behind the the dash and plugs into the OBD connector. I unmounted the OBD connector and moved it behind the fuse panel so the cover could snap on. When I need to go to the DMV for inspection I just normal it back up. Not a big deal to do every 2 years.
View attachment 1852726 View attachment 1852727 View attachment 1852728
Here’s how I have mine setup. Some redundancy from one page to another because it’s info I want to see always.
Page1
Coolant Temp
MPH
Instantaneous MPG
Average MPG
Trip mileage
Distance to Empty
Page2
Coolant Temp
MPH
Long fuel trim 1
Short Fuel trim 1
Fuel Level
Eng Load%
Page 3
Coolant Temp
MPH
Intake temp
UG Voltage
Fuel Level
Distance to Empty.
