Hello. Is anyone able to do the screenshot for 69057-22041 to see if this is still in stock or discontinued? Ignition cylinder for 1980-1984 FJ60 and other cars as well.
I see it in stock at both online dealers I use for $125.30.Hello. Is anyone able to do the screenshot for 69057-22041 to see if this is still in stock or discontinued? Ignition cylinder for 1980-1984 FJ60 and other cars as well.
Been burned by those several times. Either will say availability and let you buy only to say no dice or will say discontinued when it’s available.I see it in stock at both online dealers I use for $125.30.
Toyota Ignition Switch Lock Cylinder & Key Set #69057-22041 | Autoparts.toyota.com
Genuine Toyota ignition switch lock cylinder & key set for smooth key operation, exact fit, and factory security compatibility.autoparts.lewistoyota.com
In stock and purchaseable? At risk of being discontinued?69057-22041 is E5
Received 69057-22041. The date code on the sticker “9L19” I believe signifies December 19, 2019. So about 4 years old.
@cruiserdanYes and yes like every part for 40+ year old
I was just inside my rear gate cleaning and didn’t even know that pad was an issue, besides the rubber falling apart was there a way to see it? Last year I cleaned my pad up with some 1500 grit and heated to blacken up. Looks great but appears to be a Trojan horseRear hatch lock pad. Apparently they have metal inside and mine had a bad case of the rusts. Purchased from City Racer, however any dealer would have it.
@harrison60 Thanks for the numbers you posted for the body mounts. I need to replace my radiator and those front mounts on mine are way, way worse than yours.
That last sentence is very true haha. On the inside pop off the u-shaped keeper for the lock cylinder and undo the linkage. The lock and pad will slide free together, towards the outside. Once out, separate them and see what the pad looks like. It has metal inside and that’s why it rusts.I was just inside my rear gate cleaning and didn’t even know that pad was an issue, besides the rubber falling apart was there a way to see it? Last year I cleaned my pad up with some 1500 grit and heated to blacken up. Looks great but appears to be a Trojan horse
Edit: everything is a Trojan horse it seems
I put on a new pad about 3 years ago and its already showing signs of cracking which is bummer. It's not like we are getting baked in sun and heat in Seattle a lot of the time.Rear hatch lock pad. Apparently they have metal inside and mine had a bad case of the rusts. Purchased from City Racer, however any dealer would have it.
does this part fit 89 fj62 ?View attachment 3560010
Bought a 69057-90A08 from Amayama. The date code on the sticker “4A23” indicates January 23, 2024, so brand spanking new. This is for the later FJ62s. The design of this cylinder differs slightly from 69057-22041. It also includes the original black top key, which is 90999-00104. You can’t buy that key as a blank, but they’ll sell you 90999-00212 which has different head and is plastic vs rubber. Maybe we should submit a request to the GR Heritage program to have 90999-00104 brought back for true authenticity for us OCD folks? Lol.
Curious to know what the inventory levels of this is in the US and class code. Especially compared to 69057-22041.
