TWT -- The Wrenching Thread
Yea me either until AFTER I had bought ANL fuses :(
If you (or anyone) needs the Blue Sea ANL fuse holder, let me know - I have two extra and a ton of 80 and 150 amp fuses.
You will still need a fuse up near the battery for your 1 AWG. Given you are only going 10 feet do you have to go 1 AWG? You may be able to go smaller? You may already have it on hand.
Just read thru your thread. I went with the Blue Sea 7610, I also already have the BlueSea MEGA fuse holder and fuses. I'm going to have a 150 between each battery and the ACR, and a 125 for the 0AWG going to the back of the truck. I have a wired wagon fused relay panel for all the exterior lights, and I plan to run a small blue sea fuse panel for the interior lights. I might just hook it up with what I got, and start simplifying over time.
Steering box was leaking badly, reservoir always puked when off-camber. Enter PSC Remote Reservoir setup:
h49TiZEf3VPhJhjDVX3ekiiigdWzMa-VW28nPvaCVThqb3Cd0rApXOESFHZFqA-T19WY6TBKDUsXVOSnLqidyw_S6-THVaGmmm4jNmfU0BgTD3xdy5klLaePiIDcCJ6vf374HgsoPAJYKfBdsExNbdObiopAw_HmS-ca0Ai4phZb3sVqADlVv4ACwZz9XdNSWhD2kTeLlKpmYU9IhKKuawr7MD00Js4BABlwZTA7g9PE7f8zr0q13N7aYIZEQoq0_HBFFhP_fGH5dg2ioPe8iF0YeNkQ09C5oYjqSJB6gk_m5SWdU7ZFiRc-xU-duSh-c73yiNXEIvTAR705Y38_raw3IqQnNdrYBUP-0O2i9lf9KdXsJOvhTtogI1uloPxtxBntvcaOHg1uIbkh6isiKG9GeX-0jrRTCKVimQoQ5vmYmrXsFDDVGyEghFslKT2v5qsb9EKPDV-Zxukm9_mUd9X3AICcF6DKGuNpsf--f6AIv3ekqfrWOj6YGIkAoHKRD5R_HB5aRCRj5nlK96JR44_skxIAg5gT09SHg5xyeQbOvcRHuXrevFFqECO0sJ8qPc7Y1YCkF48aSwoQLt-G9MYB2TErPPRI5hfqRznxx2pw7a2g2BfHrg=w2698-h2004-no
Built the black bracket that bolts to the fender in OEM holes (where the carb fan used to sit):
Ca2eximFsIxDnGzxv6f6FUswGT_AbKq3F1ANnyxJaCk0UXS08LD_M12yjXMMSrpg8HAA0tVnHf5t4VDezpggvlBy_doDxaajq8vpB6BWZWJCMRhPljUE_k-4cyVH3GDls75hEsDE6DCcCFKjFX-Ku4QUlpkZDgyB80ZbM-mwy4va-zE7zKLHF_dv83I6g_hPcJ8smZgwOfcauLKRRFOmIGknlVDsq3ky5N38wJBgk7V6HEcZ1uCxMIkuiww4xCvLNmLmLlJUlqKwii1qL__cYKQtu16yFf2M35yGLHNAHesrFqvZPUr-zU10wkLjXno2ftExMEfcEXChrifX3RrVdC82LmdiM-mdP8DzvvXLaWFu7bEMf0D3_SVxnGMPSMbqwyZm6RrIZceAUc_xXfOy_skIDJD2_G7dhWMyEe8tY4IM6c8YEbjO6yA6sS8mYzUie0UyiPS-kZR1Ie-IMNmuPtZLNGyZEALVDQGFVFakJfBt9zC5GofGjpjcxJLOc1YkInLYlzvehQ56E90GNuyGtPagRnUR-WQJ74WDARzo5V3CAqBc9eY3nGihmu3qICEdRu_ojwxDygLK5oTgfnCeJxDPT4oer8T3Omi_pFlOrrunJVejxT3zFA=w2698-h2004-no
0zRgvaFKeuGLKJxIMqnFMZvFPLpx0w6Bvvrvj3dnulsNweYSPQpn4c44j2njKrxv9IdoqhXLX_8eILfcvhLxd2WB98xiVFId9KinzOCBKCgmfHu55U8RmBIDdh68-mXJwcAMHDjL-ZzjMDXnetTgb0_cJJeEmWmG7fOeViHtADWJGfSRxVdsx-pTkrnmIDIyN3QflZ56clggBr9bEN3llX-m0-YnqyqTww8p1xsSiSx-o_FCctv7z9QJHETLqstxVYmky-1oWxGt8kBJ-wUdwHjv3hQmUsZaAsdymwNkirGuTYhxNSYCrWrIjVEAJZ9WcWNDjWHsRBsy9QApFxtSvujpirCiNJKtimk_kvG3c0_15DcHlJpuimYSJqvVvGrUyxH3WP__caN8SQHkCH7VJtO4neQs4AQ0N5_XXK-CaOw8NU6jA6ilyoJ6mOQkuXDI4QQPyb50CsIjxv3HbuhnDMtCJGo7pT3ttEqONANbib4aGqB6AJtJtEY44pa51g0QbwPS4aawCYkFSaGfqyJkbBDAdozjY1K8UrRDfVbUb9qHHP5wgMvJWeskImjd1nqXLOlZ_u-zRzBHNquh2a4ocbr8n6p75iikSZ3Z67KQ7_u4ofulat1J2g=w2698-h2004-no
Resealed J8X steering box with 105 sector shaft and pitman arm, ported it while in there so I can add hydro assist down the line without opening the box up again:
qwWcQJPbQLgiDXixJD8vAMsCw9OF8OxISb6HclMyI_QDl6Ka-6DR4-Fl0cKYVX9mpuLbiIVuXKs8a8kQEgbd2ez6RyEUIXscFZCpjrZC8K5y2bLTlpUyCyTa59Wz-OwGzGEFTWR-qURjQaXnFvtFFUnij8l29S0PVRfwe9Tn2QScz1D7YZdPmawniMKyt_xVmzZtCFxxGeWIx2jdTVyKjYPSSgYyWoQm7cxwo9SK4lo9UWEVM-FiRa6xnmXgEqXvU_XnhrWgmFu_QEwbIRXDWkzyh_XGZIouzOJyi2xzqmvInPaSq3dPrLUsHaQx5nATGQ_e-3cZdjd1k-MU-ZemdELQMTb3OMyKeJ-PpBb7hjy3gExYLrWB3pxXIB5csZbNDQVDk0u5Dfgz_OI7PTdQInl9J8e-okBEosTlro6wsyxu70RAwnXX_NoXa5wCTbFQCtzq7uibJwvWhWB-sp8V5_2EmgqHPR9nlAKc68i295UIRcIhbg1vP0elgW-tVufRbjZJo9tFtf13kwdRw_AqiXYTuz9A4spkhgEHi6EZ2zyS6gsCr0hOaGOoNLJgYc66oxX3wE00kS3bwW26qePNAEo5-cSyC70ckU3MRp1IYy_ktepBWwW1yA=w2698-h2004-no
CrQ3exL0mCJCM9Wmz6WttZ6kKCG96tfnb-PlyIb3YauJ9mAj_7aeHFS302lf6QQPmVwV_Pa5uGhN9IWf7oQGxnXPl-OYCqtTYFNyUu3tnwUt5xvXHJRo2H6latXvUo03cNaEAs1OsNWg2WXRZ3PLJsUIPC4WXSsB3TQeN-CEJGbO0xJTfjQuAGYX9WIV5ejwS3F2J2jWnUgDQfQ4Z-U-RrDK4k2OGJmeOYima0_vTrwmCunY7d343VKBwk3t9AccyymGSyYy4HCWx45qlqs7t7AoFZ7cJVNH6WVIEIjI4ZFCHURt_EIswcMT8BUrcThB9QJzwmWhwaUyZ2J4l5X2PFzzhRoqO_Q82udx_2lLdPP3XhJ0iMkMyJjDKFLsEB6iog9YpjQ5WQG2My97sVg5GVgP85eLrYdYWIFBei7kvTDhN7QYirKBdIsthTEojjWmN8JQmXxYV5KVBEE8PDJfgW5odYWkpx8CrTu3YXgAA4a7EMHa2YSMOD30y7jBx7crNEzrMAtz1O2vDINUrNudexpD0LcNp8xOTQWxKdIHXlT7odN_7PiEkOUfAVM4OcZ1Hdm16yh6VQlbChmJffHlKl2bxDaQhghOwcOgYXnIThLuzLNXTGbMOg=w2698-h2004-no
c0Y-Cl6oddxjfCshteRas6VHOb8CpMbadLeLujs5hPZfPEDcICsQQiJLTb3TfanLOzyM6dQ-6J1pFydGPdBiThhPBtP1PqfVHDLtNyg-EGOFd9poQRHZSvxD3PhOCo0U2yCNc7CLzNZOvCSMvUmzaiNLnM4IgR3uIR8WbgaKnV1-NdWR0pTyUU9KYGyJ1dn_u22QI-t7Cz9-GttnESpRypS9RdA8P2dL6-vja6WTlNMSjzVF1s3Z7FLXo4djhIfH7zpxjlKR5WHKgDLaFR2g5C4soNEVdhK5WL0LL2zmNgCtZ8WJHSAiUb1wTINnv2g2aBgN3-_kk3NS-lq9V3uRRLGTz86sI2QzFRMppkVSx5DtDU3HWCxTIu9jp1vllrV1c3Z4k4NhuKCAomPUeg8IiRksUPWqeuC48Rwgb2IooO1HWSRBBaTpL5yLUTqTKeFdeiT7BAkbW1Jt10jAi2qWi_6JJbVcYNhrjq2cnevTYIS3UOWFIwLBxuSBk4w2VGWInL_OAp_okKEmWXz6j3fhFL-s1gJwb21jxwl4h9Y9RWSav65sQH9VIczmgwfxWrh0uENuIbtn9_7Ej7KbpeIMx2fct4woIXab0yASu0yxO30ksa9ORnDf1Q=w2698-h2004-no
All done. No leaks yet!!
Cy9NZN2ve1IOoS2lh_ipNso1AIiII_hMNJERijEdB4DYWkiYHJ72l9ue2yhlLblh5Ytaq9AjDevFZTpbrPLKzSyRNkD_f-lOYfJ4D8lKDN71Jty_dGkiHOQWw0fUgI8d1SpxEJNF9wuczzDuswGoRXI-6WCSywglqf50zMvADbVLb8rsknlr3Dk6QlUilkg4LivDIfQeeO4aAmWgpqIfxQdwtTj5OaoVht-M2xv7iMWKA-cAxqwoIxJ2JsW7Ch434yw7VPH9Ei6FEu5FWzQj8v7nCaMNCafFsswx6ECss1-nR1rg0AN-OfIYDdaVkxf30xY5LSvwHB_VKftlhIEvaTFdLF9izSKWSO4iW4vB4qFviJX4zDqn60pCPvFCrpfFjEyWTbo6HBhzgVpNa8_ZendIyuzWHPrK4pBr0-N48imHagEEIO2i0QxZWAT9dB3JU-Cy41hQCzdx72TFIXbLi63imbIy0h5LWxloieFZsPstje5As1p5brRqkvNhLveC8iorKYZfguxMh7mGf3uora3CbeO_FkU3H9I7mVWsaa5NNtVDJzfvHBJ7CcW2okftn9pJfsi_rJa_oPExUG4IjXCXQKc6Tn-81dvPIYQphkQcNcFzer-Bbg=w2698-h2004-no
Please look at the diagram above. I finally found the idler pulley, idle pulley bracket to complete my power steering. Quick question how do I figure out what size bolt I need?
The picture only shows the two bolts on the right attaching the bracket to the power steering pump bracket. On the left of that bracket there is a hole to attach it to my engine block.
What is the best technique to figure out the size and length of the bolt?
Any suggest would be greatly appreciated
Thanks
Dang purdy. That vise makes the steering box look small!!
Got a few things done last night on the new 4Runner:
  • changed oil - pretty dirty old stuff :( knew that.
  • did a full inspection underneath. surprisingly clean. right CV axle is spurting a bit, but we knew that. left is in good shape. didn't find any leaks, which is great news. valve covers seem to be leaking a bit - need to figure that out.
  • swapped out tires/wheels to @Rice 's old wheels - they look so nice
  • ran the sprinkler underneath the truck to get rid of some red clay dirt - have the belly plates soaking
  • purchased a new battery tie down and bolt - $24 at FAT - old owner had a bungee cord in there :\
  • engine and transmission seem very strong
View attachment 1460494 Please look at the diagram above. I finally found the idler pulley, idle pulley bracket to complete my power steering. Quick question how do I figure out what size bolt I need?
Thanks
91611-61020 These are like $0.27 each.
Wow. That's cheaper then the hardware store Chinese bolts! Good deal. Is that an M10x20?
Yes. From what I found elsewhere it is an M10x20.
Beno, I will
Call you in a few days. I want to order a few other parts while I'm at it.
Thanks for the info.
Who would of thought that the hardest part of the whole DIY4x4 labs rear bumper build are installing the shocks. These things were a pain in the butt to install. Took a lot longer than expected but it was totally worth it because I hated dealing with the swingouts on uneven terrain.
Beno, I will
I am unfortunately closed for business for the next three weeks while I relocate myself and my business to Boulder, CO from ATL.
I will be back up and running around 6/15 or so.
As much as I would like to assist on this round, I think your local supplier might be much more expedient than waiting for me!
Thanks for thinking of me.
Onur
Onur
Ok no worries. Good to know. Good luck with the move. I will hit you up next time.
Trans cooler lines. Note break at bell housing, allows motor or trans to be pulled independent without cooler lines being a problem. Two brackets keep lines in place
Noticed my inverter under my console quit working.
Install quality wire. Not cheap Chinese crap. It's not real copper.
I've preached it for over a decade. Time to take me own advice.
That is all. Please carry on.
