Guys - hope all's well. Trying to ferret out a wiring issue on my new '87 60 project, where my tail, brake, and license plate lights won't turn on. As background, I bought the 60 "not running" a week ago, but with a new battery, oil change, and some manhandling of the gas pedal, it fired right up, but has always required goosing of the throttle to keep it idling. But then I went to start it last night in the garage, and it settled into the smoothest, most beautiful idle, with no throttle inputs required. After 30-45 seconds, I went to turn on the headlights and it immediately faltered and died. Restarted with the usual jamming on the pedal, and needing to keep some extra input to keep it from dying at idle. Whether I had the lights were on or off, it wouldn't idle.
Headlights work just fine and always have, but I've only gotten the taillights and brake lights to work once. I didn't change anything: they just worked one time, and then next time I went to try them, they didn't. Also, when the light switch is turned on, the taillight relay gets pretty hot. All signs point to bad ground/short somewhere, right?
Facts:
- bulbs are good
- Light control switch is good, as I tested continuity there at all three positions (off/parking/headlights)
- TAIL fuse is good
- At the relay connections on the relay block, I'm not getting any voltage on the upstream side of either the low power or high power circuit, whether switch is on or off. But when I turn the light switch on, I get 0.1v reading on the downstream side (I think) of the high power circuit.
Questions:
- If there's a short or bad ground, are there some known spots to start looking? (Truck is pretty dry with very minimal rust).
- Could the short have engaged the alternator (which is old), making it so hard to spin that the engine can't idle without additional throttle? Anyone experienced this?
- FSM mentions a fusible link. Where is this? And is there a link for each circuit, or one overall? All other electrical on the truck works, except the instrument panel lights, which I haven't started digging into yet.
Thanks a ton!
Facts:
- bulbs are good
- TAIL fuse is good
Questions:
Thanks a ton!
