What do you use on the end for the axles to attach to? How does its all come together when you get to the point where you have the spindle mounted. Obviously your not mounting the front hub to the front 40 or 60 rotor right? I'm just confused,.
Back where? I'm still confused on how you complete this setup. If I'm not mistaken this is how it goes:
First you weld these on the axles
Second you bolt on spindles from and fj60
Third you mate fj60 rotors to the hubs as usual
Fourth you slid the rotor and hub assembly with bearings installed over the spindle.
Fifth?? You instal the locking hubs on a set of custom axles?? Which are always locked?? Or do these custom axles replace the whole locking hub assembly??
I think the other poster was referring to using drive flanges on the rear axle with floater shafts instead of locking hubs like Aisins or Warns.
The Nitro cut to length axles are built just like the factory full floater axle shafts, with a drive flange permanently attached. So rather than attaching a locking hub, you slide the shaft in and bolt it up.
More info: Nitro Full Floater Axles
Not for me...
Wouldn't those axles just take place of the locking hub?
I'm thinking that those axles bolt right onto the hubs where the locking hubs would go, using the cone washers and studs out of the hubs??? Those studs on the hubs are pretty small...... Not sure how strong that would be. I guess if its strong enough for the front it's good enough for the rear right?
chicago said:I JUST GOT this!!
I see what your looking at, finally!! So the axle flange IS the cover!!
I'll get it!!
I do believe that is how it works.
Wonder how strong that would be? Why would poser use em?
chicago said:Would your concern be the hub studs??
What do you have??
