- Joined
- Sep 19, 2007
- Threads
- 145
- Messages
- 1,531
- Location
- Colo Spgs Colorado
- Website
- www.redlinelandcruisers.com
here is a shot of the spindle!
Taco brakes in the front?
Front Range Off Road Fab also makes a kit to adapt Taco Brakes.
I used this kit to mount Tundra brakes to my 60s front diff.
With the Tundra stuff you will need a 17" wheel or a large spacer though.
You may be right, the 16" may fit, but i knew the 17" would for sure.
There are also two different Tundra calipers and i am not sure if they are bigger.
Redline, can you tell us how much the FF conversion widens/narrows the rear end assuming you cut off right at the backing plate for the drum brakes?
Couldn't the bearings be run "wet" like a Dana60 (or most rear FF for that matter)? Don't know if the fluid level runs high enough in the housing to keep the bearings wet, but it would solve the inner axle seal problem.
Just a thought...
