projectTuRD
1969 fj40
I’ve read about bad grounds. Most of the lights work in some form or other so I think the grounds are good.
My rear lights are questionable led units. They’ll be replaced with oem at some point.
be perusing the wiring diagram some more but the flasher unit seems to be good.
Any thoughts on where to start?
Turns out the hazard flasher works, makes some of the lights blink.
The front left, which stays on when the turn signal switch is used, doesn’t come on at all with the hazard switch.
the rear left stays on with the signal switch and blinks with the hazard switch.
The right rear doesn’t come on with the signal or hazard switch.
The right front stays on with the signal switch, blinks with the hazard switch.
