thebigredrocker
- Joined
- Nov 5, 2013
- Threads
- 60
- Messages
- 3,596
Re: testing the right side turn signal/markers. If you have gator clips you can clip it to the front mounting bolt and then to bare metal(preferably frame). Or just wrap some wire around the bolt and a ground location, your close enough to battery negative you could just stuff a wire in the battery post clamp.
Don't forget to eventually clean some bolts that fasten the front fenders to the frame. Might not hurt to chase threads of the dedicated fender nuts welded to frame.
Some of my grounds may be overkill, here's a front fender to frame ground on my 76
Rear frame to tub ground(need to move the bolt)
