Turn Signal Headache
Idaho Savage
GOLD Star
Idaho
Yes, I think I have read every thread on mud on the topic and can't seem to make sense of my situation.
1. Turn signals suddenly went out.
2. Hazards still work
3. Replaced Flasher relay to no avail
4. Checked and even swapped fuse
5. Swapped switch (I have a spare tree assembly in my parts pile) and made no difference.
So the bulbs are fine (hazards work). Fuses and relays and switches are all seemingly fine.
What am I missing?
Any help would be appreciated.
Could you have a wire in the harness that’s shewed up or cut?
Check your grounds!
Turn signals and hazards use different fuses and have different power supply (hazards work with the ignition swith off). You checked the turn signal fuse? did you also check that you have power going to that fuse when the ignition switch is on?
