Right, which is why I am not blaming you nor have I.
I'm merely relaying my experience.
This is not your fault. Absolutely mine in that I did not do my research and due diligence before just slapping something onto my truck. And the research I did was cursory, at the time.
I have and will continue recommending your kit to other 3B owners mainly because of the fact that it is domestic and supports a small company.
I understand, but what I really need to know is what's wrong with the kit that makes it inferior? Which components need to be upgraded or changed? I have always searched for higher grade items to include or change. You recommend the copper gaskets, but even before we changed those the others weren't a problem. The new ones were made from the same material that Boeing uses I found on some parts we were doing for them. They turned me onto their maker and I had them make our gaskets. Much more expensive yet I still ate the extra costs. So if the one inlet adapter is to large and causing turbo failure I need to know so I can investigate it. I don't doubt you had a problem but why then hasn't there been other complaints over the last 8 or so years since I developed the kit. I can only think of one guys some years back that had a similar problem. He contacted me I contacted Garrett who rebuilt his turbo for free. It has ran fine ever since. Maybe it was a bad turbo, absolutely can happen. But a 3B with high oil pressure blowing a turbo up I have never seen. So that the viewers here understand and my company can benefit, please advise me as to what is cheap or inferior to a $10,000 turbo system. I will change it.
