Wow, thats nice. Are the 5 teets the pour points? The flanges seem to be really thick. By recollection about 1/8th thicker than the stock manifolds. Will those be milled down? If not, what about studs? I always thought that part of the reason that the exhaust manifolds are 2 piece was to cope with the aluminum head and the difference in the rate of change of thermal expansion. If this is so, Could one slightly elongate the stud holes to allow for a wee bit of differential movement between the head and the manifold. I appologize if you have covered this topic already.
Once again, I admire your work.
Karl
Thorough, very thorough.
As I hoped, you took my comments as mere points of discussion. Thanks.
Karl
Did that motor come from the bottom of Lake Michigan?
Very very nice Rick, now the fun finally begins!!!![]()
