- Joined
- May 11, 2009
- Threads
- 1
- Messages
- 4
I have a 2000 Landcruiser. I found a set of new take off 2008 Tundra wheels/tires and I wanted to know if these would fit my LC? Thanks in advance.
MARCFJ60 - I may have OEM 16"'s for sale if I end up with the 18"'s I am considering.
Will the caps from my OEM 16" rims fit?
I have a 2005 Land Cruiser and for years ran the standard Toyota Tundra 18" 5 spoke rim (not TRD; but looked quite similar to those 20 rims pictured directly above on the tricked out Galactic Gray LC in this thread; but mine were 18". I did *not* have a problem with the front hubs on those 18" Tundra rims, but I *think* that I might have used the plastic covers from my original 5spoke LC rims (but might have been the same as Tundra placstic center hub covers?). Cant remember. But, I ran them for 5 years and they looked great (just went back to orig OEM LC rims, but considering those 20's pictured above! BUT, looking at newer 20's from an 08" or newer Tundra or newer 08-14 LC 18" rim and wondering if they will fit on older .05 LC. I hear the offset of new ones is 60mm, vs. the 98-07s LCs used a 50mm offset. Even Toyota dealer (boston) didn't know if they would fit/rub? I can't imagine one cm being a big deal given the good clearance now present with factory setup? Advise, anyone. ?But those are 20" wheels, right?
here is mine
it rubs alittle and the front hubs had to be trimmed.
Hi - I'm curious - where specifically does it 'rub a little', and in hindsight was it a mistake? (i.e., rub too much -wear on car (or tire), or puncture/denting any time? thankx, mike.
