Trying to Sort a Parasitic Draw - Needs some input
Hugh Heifer
What we gonna do today, Brain?
Rome, GA
Website
www.stlca.org
I have been suffering a parasitic draw ever since I arrived in PI. I finally had a day off and got to trying to sort it. My first thought is it has to do with the IBS with the RBM add on.
I am running a Group 31 battery for my main and an Optima Blue for my secondary. The Optima never goes dead so it would seem that whatever is causing the problem is being properly isolated by the IBS system.
We often go about two weeks without driving the car sometimes maybe three but I would think that if I was not suffering an over 50mA draw that big DieHard Group 31 would be fine for a month or more.
I pulled all the negative cables of and started by testing each ground. (I have one main, one to the body, one to a solenoid for my offroad lights, one for the winch and one that goes to my IBS controller). I found a .05 Amp curren on the winch that I found odd. I would not think that would draw current at all when off. But then on the main ground with none of the others touching I found a .19 Amp draw. The ground for the IBS controller was not hooked up. I went about trying to isolate the issue by pulling fuses starting with under the hood. There was nothing big until I pulled the AM2 fuse (which I think controls the ignition module) and the amp draw dropped way off. I plugged the fuse back in the amps did not jump. They stayed at .05/.06 (I read .05 or 50 milliamps is the magic number for a car while shut off.)
I hooked everything back up though I unplugged my ScanGauge and I also disconnected the plug at the back of my IBS controlled as I discovered some weird stuff with that.
Here is some of the weird:
When I had unhooked all the ground leads from the main battery and not the aux battery, the IBS showed both batteries good and that they were linked. (The main was unhooked completely.) I found that all the accessories and ignition worked. For some reason, the IBS linked automatically making my second battery my main (or thinking it was both really). The other thing I have noted is that for some reason the IBS begins to beep while driving for 30 minutes or more. I believe this is the "Link Failure Alarm." I have read this is an indication of either overheating of the system or a bad battery that will not charge. But my alternator is charging my batteries fine. There is very little information regarding the "Link Failure Alarm" or link failure at all. (Although I did just find this but have no idea WTF it means:
"The system monitors the charge on both batteries. If the system senses at an applied load (alternator, solar, charger) that there is no charge on the other battery, the link fault alarm with a flashing green LED "linked" is displayed and you hear the beep. If this error occurs, you should immediately check the wiring of power cables (relay, battery terminals, crimp contacts, control relays). Once the errors are corrected, the alarm will automatically reset.")
I have a feeling that the IBS system is failing and causing a parasitic draw while the car is not running and then not acting correctly during regular operation. Unfortunately the site does not have very good instructions or a very good trouble shooting section.
Questions:
1. What all does the AM2 fuse control (yes - I am certain I could rtfm but I have not yet)?
2. On my 2000 100, could having a chipped key nearby cause the ignition circuit to "charge" in anticipation of starting? (This could explain the high amp draw from the ignition circuit as the key was laying on the driver's floor mat.)
3. Do any of you guys have any experience with the IBS system or hear from anyone who has it and has had trouble with it? IBS touts their system to have less than a 1mA draw. I think I may be incurring more than that.
3b. If I unplug my IBS monitor/controller what effect might that have when running or not running? (ie my batteries trying to balance one another.)
4. I think I know the answer to this one - Does the ScanGuage II know to shut off when the car is not running or does it draw some current? I experienced trouble with one of those Bluertooth OBDII senders that stayed on all the time searching for signal even when the car was off.
5. If I have two or three things pulling .03 amps each, this compounds right? So if I had a .05 on the radio and other stock stuff, .05 on the winch and .06 on the IBS monitor unit that would put me a little high at .16 which could be enough I guess to kill a battery in a couple weeks? Thoughts on that?
I disconnected the Group 31 and put it on the battery tender for about 5 days. It charged up to 12.5 and as I checked the voltage I watched it drop to 11.9. Pretty sure the battery is toast. 3 year old DieHard Platinum Group 31. From what I read maybe we need bigger alternators to charge those .... or maybe it is just too damn hot here.
A bad battery would account for the odd messages being sent by the IBS monitor.
Good batteries are impossible to find here.
I don't think the key being close does anything. It just has an RFID in it for identification purposes.
If you have an ignition draw maybe you have a relay stuck on or something broke.
The AM2 fuse runs the injectors and ignition.
Something broke is not out of the question but it does appear the battery is jacked up. Like I mentioned I read there have been a bunch of trouble with them.
Wheb I get back from NZ I will check the voltage and see if it has dropped considerably without being connected to anything. That will be the tell.
I have my large battery charger here. I may try to put it on that and see if it desulfates it....or whatever it is called. If I could get by another 6 months on the Diehard it would not be a bad thing.
Something broke may have killed the battery with a constant drain, so if the battery is bad it doesn't really tell you the answer. ;)
was at 11.4 when I got home from vacation and it had been unhooked. The charger threw the code for an open cell. I an going to get an Optima Group 31. I found 1 here. Ain't cheap but I get tax off so that helps. Hopefully I have luck with that.
Funny. I haven't hooked the battery up. Just dropped it in the truck. That mean I have not driven the truck since July. :lol:
Took a Jeepney for the first time the other night though.
It was not the relay. It turned out to be the RBM relay for the DBS. I posted something about it in electrical. I removed it completely and all is good now. Will get a new one once I am settled back in the US.
