kevinmrowland
Forum Lifer
Does any one else have trouble with sealing where the flanged exhaust pipe bolts to the bottom of the exhaust manifold?
I have never been able to get it to seal real well, putting two doughnuts in there makes it alright but not great.
Replaced the manifold gasket & while it was out I checked that the seat was flat, seemed ok.
I thought that maybe the rest of the exhaust was not letting the flange sit flat so I cut it off to just deal with the down pipe.
The flange on the pipe was bent where the main bolt pressure is, so I heated it up and bent the wings back.
Made an aluminum spacer to sit on the flange to hopefully shove the doughnut tighter into the manifold, that did not work at all.
After all that I put it back together with 2 doughnuts and it leaks just about as much as when I started this whole thing a few hours ago.
I figure I would ask if anybody had any great tricks before I went and welded the exhaust back together.
Thanks, I'm off to search now.
Kevin R.
Kevin R.
