I started with a motor that had done 50,000km since complete rebuild, pulled it to pieces to port and polish the head and found this:
Fxxx, you wouldn't believe it, cracked to #5, all 6 pre cups cracked. I've got the reciept for the motor, but something does not add up. Maybe he lied about the K's since the work was done. There is no km on the invoice.
Pistons and cylinder bores look A1. Uses no oil. Blows no smoke.
Standard 10mm VE running on one of the medium sides of the pin, 10" barrel WTA, Denco Turbo, was only averaging 300C post EGT, tappets were all within spec, I haven't checked the timing yet, but I'll set it to 1.09 when I do.
Observations:
The EGT probe was 200mm past the turbine exit so I'm thinking that it was reading low.
New EGT probe position with probe tip 50% into pipe:
I don't know what the AFR was running at previously but I have installed digital on board AFR for restart/tuning.
It's running LPG over the top. I have seen arguments for and against, I can't make my mind up about this one, but I love the clean burn and the extra boost I get when it comes on so I'm hesitant to take it off.
I took the head to Davilak's in Hamilton Hill (I've used them for 25 years) for a quote on cracktest and weld.
They said don't bother no one repairs these things. That's when I started stressing out...
But there is a happy ending - they sold me a complete brand new 1HZ head for $1200, the cheapest I can find on eBay is $1650. All I have to do is fit the cam gear and bolt it on. So a good result in the end.
I'm still going to match port and polish
What is the concensus on the LPG?
Observations:
