Looking to get a set of OEM fender flares and mud flaps for my HZJ75 troopy. So far I've seen them on newer 78 models, so does any know whether or not TOYOTA made them for 75s?
So the newer 78 has the same rear wheel arch as the 1996 hzj75rv?You can just use the OEM flares intended for any heavy duty older narrow nose (still available last time I looked) for the front and the OEM 78 troopy flares for the rear. Just make sure you get the correct mud flaps too.
Also, in this case, the rear will stick out more than the front?You can just use the OEM flares intended for any heavy duty older narrow nose (still available last time I looked) for the front and the OEM 78 troopy flares for the rear. Just make sure you get the correct mud flaps too.
saw his thread, but I believe he ended up getting a set of aftermarket flares
Found these for 71, wondering if they're the same fit as 75 troopy
View attachment 3190528View attachment 3190529
Hello,Found these for 71, wondering if they're the same fit as 75 troopy
Yes, I have a dual tank.Yes, assuming you have a dual tank 75 Troopy.
Get with Dave (stedman@japan4x4.com) and tell him you want the same rear flare setup as me. I believe we ended up on 74/73 part numbers.
For the fronts you can use pretty much any HD narrow nose flare. Don't have him order the same fronts as he sourced for me, I have a wide-nose.
also what size wheels/rims are you runing with the fender flares?Yes, assuming you have a dual tank 75 Troopy.
Hello,also what size wheels/rims are you runing with the fender flares?
